Communicating with PLC using serial COM
Hi all,
I am trying to control a Duet 3 6hc with a PLC through a serial COM.
The Duet is running firmware 3.5.3
The PLC sends RS232 commands connecting to IO_0 on the board.
Is there a procedure or hardware for setting this up? Any guidance would be greatly appreciated. -
@mkr38 just M575. You need to set the correct speed etc and whether you use a checksum too (you probably won't). And then just send away
@mkr38 please ensure your voltage level for the plc rs232 is compatible with the Duet IO level.
I have used this in the past for rs232 to UART
https://uk.rs-online.com/web/p/communication-wireless-development-tools/8829042?gb=s
