3.6.0-beta.2 Pressure Advance Issue?
I think I have found a bug with pressure advance on G2/G3 moves. It seems that the extruder just quits extruding around medium sized holes (about 15mm). When I slice the model using only G1 moves I get a nearly flawless print. However, if I change the slicer to use G2/G3 moves I get no extrusion on the holes around 15 mm in diameter. If I set pressure advance to 0.0 the holes print fine, however I get all the artifacts one would expect from not having PA. I would love to include pictures, but it seems as though I do not have the pillages for that yet.
Some info about my machine and config:
It is a Railcore ii based CoreXY machine. I am printing at 200 mm/s and 10k mm/s^2 accelerations.Potentially relevant config.g info:
; Axes
M584 X0 Y1 Z5:6:7 A6 B7 ; set axis mapping
M350 X16 Y16 Z16 A16 B16 I1 ; configure microstepping with interpolation
M906 X1400 Y1400 Z1000 A1000 B1000 I30 ; set axis driver currents
M92 X200 Y200 Z1600 A1600 B1600 ; configure steps per mm
M208 X0:320 Y0:302 Z0:345 A0:345 B0:345 ; set minimum and maximum axis limits
M566 X500 Y500 Z30 A30 B30 ; set maximum instantaneous speed changes (mm/min)
M203 X36000 Y36000 Z900 A900 B900 ; set maximum speeds (mm/min)
M201 X10000 Y10000 Z1000 A1000 B1000 ; set accelerations (mm/s^2); Extruders
M584 E3 ; set extruder mapping
M350 E16 I1 ; configure microstepping with interpolation
M906 E1250 I30 ; set extruder driver currents
M92 E837 ; configure steps per mm
M566 E2000 ; set maximum instantaneous speed changes (mm/min)
M203 E3600 ; set maximum speeds (mm/min)
M201 E5000 ; set accelerations (mm/s^2); Kinematics
M669 K1 ; configure CoreXY kinematics;Input Shaping
M593 P"ZVDD" F65 ; use ZVDD input shaping to cancel ringing at 65Hz;Pressure advance
M572 D0 S0.02 ; set extruder 0 pressure advanceThis was also a problem in 3.5.4 except that I had the same issue even with G1 moves around medium sized holes. Additionally in 3.5.4 it seemed like input shaping was not applied to G2/3 moves. Based on my limited testing it seems the new input shaper algorithm is applied to G2/3 moves which is fantastic news!
I had been tearing my hair out trying to get PA and input shaping to work on 3.5.4. After some testing it looked like input shaping was not applied to G2/3 moves so I switched to a ridiculously fine gcode resolution in PrusaSlicer to get arcs to print smooth with my newly set accelerations. (with default resolution cylinders/arcs were quite choppy!). PA still just quit extruding around medium sized holes. Then I came across another forum post stating that an issue with PA was solved in the 3.6.0-Beta, so I immediately installed, and my issues disappeared! (while using G1 moves only.) Then I attempted to use G2/3 moves to eliminate the need for the high resolution to get smooth arcs. To my disappointment, my PA issues re-appeared. This is very repeatable.
