Dual X Axis Motors with Dual Endstops. Homing togethor
Duet 3 Mini 5+ Wifi
my X axis has two X motors, each with its own X endstop
I want them to both home simultaneously. and then each stop independently. to square the X axis each time.I have Split X2 to be U
; Drives Configuration M569 P0.0 S1 D2 ; Drive 0.0 (X motor) forwards M569 P0.1 S1 D2 ; Drive 0.1 (U motor) forwards M569 P0.2 S0 D2 ; Drive 0.2 (Y motor) backwards M569 P0.3 S1 D2 ; Drive 0.3 (Z motor) forwards ; M569 P0.4 S1 D2 ; Uncomment if you have an extruder motor on drive 0.4 ; Motor Idle Settings M906 I30 ; Set motor idle current to 30% M84 S30 ; Set idle timeout to 30 seconds ; Axis Mapping M584 X0.0:0.1 Y0.2 Z0.3 E0.4 ; Assign drives to axes (both X motors to X axis) ; Note: E0.4 is for the extruder; adjust if necessary ; Microstepping and Steps per mm M350 X16 U16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation M92 X80 U80 Y80 Z400 E420 ; Set steps per mm ; Axis Limits M208 X0:400 U0:400 Y0:300 Z0:200 ; Set axis travel limits for X and U axes ; Motor Currents M906 X800 U800 Y800 Z800 E800 ; Set motor currents (mA) ; Accelerations and Speeds M566 X900 U900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min) M203 X6000 U6000 Y6000 Z180 E6000 ; Set maximum speeds (mm/min) M201 X500 U500 Y500 Z20 E1000 ; Set accelerations (mm/s^2) ; Kinematics M669 K0 ; Configure Cartesian kinematics ; Endstops Configuration M574 X1 S1 P"io5.in" ; X axis endstop at min position on io5.in M574 U1 S1 P"io6.in" ; U axis endstop at min position on io6.in M574 Y2 S1 P"io3.in" ; Y axis endstop at max position on io3.in M574 Z1 S1 P"io4.in" ; Z axis endstop at min position on io4.in
HomeX code
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v3.5.5 on Mon Nov 11 2024 17:58:55 GMT-0500 (Eastern Standard Time) ; increase Z G91 ; relative positioning G1 H2 Z5 ; move Z relative to current position to avoid dragging nozzle over the bed G90 ; absolute positioning ; home X G91 ; relative positioning ; calculate how far X can travel to the max endstop var maxTravel = 200 M584 X0.0 X0.1 ; split X motors for independent homing (both motors should move simultaneously) G1 H1 X0.0-200 X0.1-200 F600 ; coarse home both X motors simultaneously and independently G1 X5 F6000 ; move back 5mm G1 H1 X0.0-200 X0.1-200 F300 ; fine home both X motors simultaneously and independently M584 X0.0:0.1 ; rejoin X motors to move together G90 ; absolute positioning ; decrease Z again G91 ; relative positioning G1 H2 Z-5 F6000 ; move Z relative to current position G90 ; absolute positioning
so far its not homing properly
things move fine when im manually moving X. but when trying to home X and U (X2) at same time U isnt moving -
@Adamfilip ok I got it working
hope this helps someonethis is my revised home X
; homex.g ; called to home the X axis ; increase Z G91 ; relative positioning G1 H2 Z5 ; move Z relative to current position to avoid dragging nozzle over the bed G90 ; absolute positioning ; home X and U simultaneously G91 ; relative positioning M584 X0.0 U0.1 ; split X and U motors for independent homing (enable endstops) G1 H1 X-200 U-200 F600 ; coarse home X and U motors simultaneously M584 X0.0:0.1 ; rejoin X and U motors to move together G90 ; absolute positioning ; decrease Z again G91 ; relative positioning G1 H2 Z-5 F6000 ; move Z relative to current position G90 ; absolute positioning and here is my config
code_text
; Drives Configuration M569 P0.0 S1 D2 ; Drive 0.0 (X motor) forwards M569 P0.1 S0 D2 ; Drive 0.1 (U motor / X2) backwards M569 P0.2 S0 D2 ; Drive 0.2 (Y motor) backwards ;M569 P0.3 S1 D2 ; Drive 0.3 (Z motor) forwards ; M569 P0.4 S1 D2 ; Uncomment if you have an extruder motor on drive 0.4 ; Motor Idle Settings M906 I30 ; Set motor idle current to 30% M84 S30 ; Set idle timeout to 30 seconds ; Axis Mapping M584 X0.0:0.1 Y0.2 Z0.3 E0.4 ; Assign drives to axes (both X motors to X axis) ; Microstepping and Steps per mm M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation M92 X80 Y80 Z400 E420 ; Set steps per mm ; Axis Limits M208 X0:400 Y0:300 Z0:200 ; Set axis travel limits ; Motor Currents M906 X1100 Y1100 Z800 E800 ; Set motor currents (mA) ; Accelerations and Speeds M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min) M203 X6000 Y6000 Z180 E6000 ; Set maximum speeds (mm/min) M201 X500 Y500 Z20 E1000 ; Set accelerations (mm/s^2) ; Kinematics M669 K0 ; Configure Cartesian kinematics ; Endstops Configuration M574 X1 S1 P"io5.in" ; X axis endstop at min position on io5.in M574 U1 S1 P"io6.in" ; U axis endstop at min position on io6.in M574 Y2 S1 P"io3.in" ; Y axis endstop at max position on io3.in M574 Z1 S1 P"io4.in" ; Z axis endstop at min position on io4.in ; Tools Configuration M563 P0 D0 H1 F0 ; Define tool 0 M568 P0 R0 S0 ; Set tool 0 active and standby temperatures to 0C ; Allow Movement Without Homing M564 H0 S0 ; Allow movement without homing
@Adamfilip you also could not split the axes and set the endstops pins in one M574 in the order if the defined motors separated by + signs. See https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_auto_levelling#axis-levelling-using-endstops
@oliof Awesome thanks for that!
