Bookworm & 3.5 upgrade attempt using guide. Filezilla fails
Trying to backup my existing 3.4.0 + SBC debian pi install - config and macro's - using the SBC Bookworm guide in the linked docs.
However; I cannot get Filezilla to authenticate / login to my pi.
Status: Connecting to 192.168.1.xx...
Status: Using username "pi".
Status: Access denied
Error: Authentication failed.
Error: Critical error: Could not connect to serverSSH is enabled. changed passwd - several times to : raspberry
Have access to the pi via vnc and i have a kb / mouse and monitor connected to the pi
@SputnikOC3d If you're using a standard Debian install, rather than the DuetPi Buster install, maybe SFTP/FTP isn't enabled? Otherwise, plug in a USB drive to the Raspberry Pi, and copy everything but firmware and www from /opt/dsf/sd that way.
@droftarts thank you ...
New twist
Now ive got mismatched FW on the main board [ just fixed ] and the iLC toolhead. tried a M997 S3 B121 [ as the DWC tells my my toolhead is 121 ] - error Error: M997: Firmware file Duet3Bootloader-SAMC21.bin not found
Ive used the dwc prior to flashing new sd card - to zip up and save all my config / sys / macros files and stored local ... need to try and get this toolhead updated properly.
Wil say - it'd be nice to have real world use examples in the docs / GCode Dictionary ...
[[ 3 - update the bootloader on the CAN-connected Duet 3 expansion board specified by the B parameter. In older Duet 2 firmware versions, was used to put the WiFi module into bootloader mode, so that firmware can be uploaded directly via its serial port. ]]
[[ On Duet 3 only this command take an optional B (board number) parameter which is the CAN address of the board to be updated, default 0 (i.e. main board). ]]
then .. get the BT wireless kb mouse on the voron to reconnect - VNC enabled ... fortunately DWC is rocking
@droftarts - this issue is resolved - and now im into a new issue.
Ive abandoned the filezilla bu and just used the filed from the DWC backups.
Closing ... moved on
