new version of firmware
File 0:/gcodes/spoilboard 1.tap selected for printing
Warning: M6: Command is not supported
Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
24/10/2024, 22:01:14 Upload of spoilboard 1.tap successful after 0sthis is a 750x750 cnc router machine
using v-carve desktop v 11.5
post processor is G-code Arcs (mm) (*.tap)any ideas what wrong ?
@waynehuish well it tells you there doesn't it?
M6 isn't a valid gcode in RRF.
And ages ago, homing moves were changes from G1 S1 to G1 H1.The G1 S1 changes to G1 H1 will probably be in your homing files.
You'll need to look at your settings in vcarve to see what it thinks it's using M6 for -
@jay_s_uk in GRBL and variants, M6 is tool changer command ...
@waynehuish Please post your config.g and the repsonse to M122.
Do you mean you have recently updated the firmware on your controller board? What version were you running before, what are you running now? Which Duet board? Is your machine something like an Ooznest Workbee?
If it's to do with the firmware and the V-carve software Ooznest provide, you would be better off contacting their support.
