Need help setting up
@Manrhpg1 Have you already seen the documention for setting up a system? https://docs.duet3d.com/
@cosmowave Man, I am not tech savvy whenever it comes to programs now if you tell me to build a 3-D printer, I can build it if you tell me to build a CNC machine I can build it. I just need help with somebody to program my 6‘ x 5‘ 3-D printer if you can guide me into doing that that would be perfectly fine, I just need help getting it to go home. I need help getting it to the machine. I don’t hook everything up. I just don’t understand how to get the motors in the right frequency is a lot.
@Manrhpg1
Ok. How far is your building?- Do you have built the X and Y axis completely?
- Do you have already installed homing switches?
- Is your board already running?
@cosmowave I am done with the machine. I just need to add the Z AXE in the middle. I wish I could Send a picture, but I don’t even know how to do that on here lol
@cosmowave yes, I have Running X and Y axis motor set up I have the board running. I just don’t know how to set up the programming in duet 3-D
And rrf -
@Manrhpg1 It depends very much how your machine is built.
You can start with the configuration tool for an initial setup. See https://docs.duet3d.com/en/How_to_guides/Configuring_firmware -
@cosmowave bro, I will pay you $200. If you set this machine up for me I will pay anybody $200 that they just set the stupid commands for this machine to work right
We can help you set it up, but you'll have to give us a lot more details about the printer. Photos would help. You'll have to meet us half way though and try and learn a bit as you go.
Starting with this guide to get connected to the board: https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
@Manrhpg1 said in Need help setting up:
Whit a little bit patience, you can do it by yourself. When you're able to build a Printer or CNC, i'm sure you can learn to setup the board and FW. As @Phaedrux said, pictures of the printer and the wiring would help. You can easy post pictures whit the picture upload
@Manrhpg1 Do you mean Ivan Miranda ?
which printer model did you follow, and what files did you download from his website.Duets need to have the end switches to be homed before any other movements are normally recognised, you can get around this by M commands used in the console area of DWC control panel.
You can if you wish contact me directly and we can have a video chat and you can show me what you have got, I would be happy to try and help you and advise accordingly.
Where are you based in the world and we can arrange a meet on WhatsApp.
Contact me on WhatsApp Shaun Richards
