Latest update - 3.5.3 - not correctly installed after update
Updated the Raspberry Pi through usual route, All proceded normally except the reported version of the Web interface is 3.5.2 on the 'General' tab under settings.
There is also a warning about dissimilar software versions on the console "Incompatible software versions
The installed software versions do not match. Please operate your setup only at equal versions to avoid potential incompatibilities and unexpected errors."Done a forced re-install via the command line of the Pi and it says 3.5.3 is installed already then proceeds to overwrite 3.5.3 with 3.5.3 ...
I ran M997 S0 but that didn't do anything to resolve, I then took 3.5.3 direct from Github and manually wrote the version (extracted of course) to the SD card of the Pi.
No change - not sure what else to do now
@Garfield clear the cache in your browser, that's usually the problem
@jay_s_uk well I'll be - never had to do that before - but it worked - many thanks
