Duetwebcontrol version missmatch
When i updated my firmware and duet web control from 3.5.0-rc.4 to 3.5.2 it seems to work fine. However after a restart the duetwebcontrol version is reported as the old version from the interface (3.5.0-rc.4). However if i check the apt package version duetwebcontrol is still installed as 3.5.2.
So its only reported as the old version in the web interface, causing a warning due to incompatible SW versions.
From the interface:
Product Short Name Version
Duet 3 MB6HC MB6HC 3.5.2
Duet 3 Expansion EXP3HC EXP3HC 3.5.2
Duet Software Framework DSF 3.5.2
Duet Web Control DWC 3.5.0-rc.4From APT:
duetcontrolserver/unstable,now 3.5.2 arm64 [installed,automatic]
duetpluginservice/unstable,now 3.5.2 arm64 [installed,automatic]
duetruntime/unstable,now 3.5.2 arm64 [installed,automatic]
duetsd/unstable,now 1.1.0 all [installed,automatic]
duetsoftwareframework/unstable,now 3.5.2 arm64 [installed]
duettools/unstable,now 3.5.2 arm64 [installed,automatic]
duetwebcontrol/unstable,now 3.5.2 all [installed,automatic]
duetwebserver/unstable,now 3.5.2 arm64 [installed,automatic] -
@snisse try refreshing the browser cache
@oliof Ah thats a simple fix, opened a ingonito window and could see the correct version, thanks
