M997 and missing sdiap on slave board
is there a way to overcome this without pulling SD card out on the slave board?
I am trying to update miniplus firmware on a board that has can address 4Error: M997: In-application programming binary "0:/firmware/Duet3_CANiap32_Mini5plus.bin" not found on board 4
@Aurimas no. You need that file on the SD card and the only way to get it there is to pull the SD card and do it manually
