motor not moving
@droftarts it doesn't appear in the ports when i connect it, i tried a different cable and different port but it doesn't work
Have you tried the reset procedure to clear the firmware again with the erase jumper?
What lights are visible on the board when you connect by USB? -
@Phaedrux well the usb light is on, so idk what's wrong
sorry i was on vacation -
@Phaedrux said in motor not moving:
@Phaedrux i thought i did, but i just did it again and it worked
@Phaedrux i still can't access dwc tho
Have you been able to view the files on the SD card on your computer yet?
@Phaedrux how do i do it outside of dwc or an sd slot?
You would need an SD card reader of some sort to access the files on a computer. There is no way around that.
@Phaedrux is it possible like with a phone plugged in a computer?
I don't know about that, but I know you can get a USB SD card reader for a few dollars.
@Phaedrux ok i'll look for that, thank you
@Phaedrux i have the sd card reader, now what am i supposed to do so i can access dwc?
Can you take a screen shot of what your root folders look like on the SD card?
Is there a folder named WWW?
Download this zip file
https://github.com/Duet3D/DuetWebControl/releases/download/v3.5.2/DuetWebControl-SD.zip
Extract the contents into the WWW folder. Replacing the files that are there if they are there.
Try connecting again.
@Phaedrux there is already a file named DuetWebControl-SD.zip, is that normal?
@Phaedrux so the only files that should be left in www are the ones in the dwc sip file?
@zecreton *zip
Yes. You can delete the entire contents of the WWW folder and replace it with the contents of the zip file.
