Stepper motor problem
The stepper motor vibrates a lot and produces noise, if I add this kind of stepper motor driver, can the above problems be solved well? https://www.oyostepper.de/goods-111-Digitaler-Schrittmotortreiber-DM542T-Schrittmotor-Treiber-10-42A-20-50VDC-für-Nema-17-23-24-Schrittmotor.html
@jonas22 what motor are you using, and how are you currently driving it?
@jonas22 does it only vibrate and produce noise, or does it actually move as commanded while it vibrates and produces noise?
