Wifi of printer not recognized by computer
I just received a Duet2 wifi board with external antenna a few days ago. I was able to set up my network and password and connect via DWC. However, i was having issues with my stepper motor for extrusion where I would hit retract and it would extrude and then retract after hitting the button a second time. Someone recommended that I delete my config files and upload new ones to see if this would fix the issue. However, after doing this my computer will no longer connect to the wifi of the printer. I can connect to the board via USB and set a network access point there, but when I disconnect the USB after turning on the access point, the network of the printer never shows up.
@Hlwanczyk Please post your config.g file, a photo or two showing your board's wiring, and the commands you used to set up the access point.
Here is my config file as well
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.16 on Fri Aug 25 2023 15:49:36 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"ChangeMyName" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M92 X100.00 Y100.00 Z500.00 E15360.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z300.00 E300.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z1200 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X-100 Y-100 Z-20 S1 ; set axis minima
M208 X100 Y100 Z200 S0 ; set axis maxima; Endstops
; WARNING: No endstops configured; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X-85:85 Y-85:85 S20 ; define mesh grid; Heaters
M140 H-1 ; disable heated bed (overrides default heater mapping); Fans
M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off; Tools
M563 P0 D0 F0 ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
M552 S2 -
@elmoret Here is a diagnostic report I performed as well.
Your config.g file has a M552 S1, which tells the board to enable networking as a client, not an access point. Board's just doing what you're telling it to
@Hlwanczyk You are currently enabling your WiFi module in your config.g file as a client with:
But it looks like you actually want to operate it as an access point. If that is correct you should replace the above line with
M552 S2 ; enable network
@gloomyandy and @elmoret Thank you! I will change the config.g file and see if that fixes the problem.
