[3.5.0-rc2] Head Crashing into the print at the end of the job
Hi Gents,
I have one issue where at the end of the printjob the head moves like its returning to a previous position, and collides with the print.
What i have figured out so far:
The gcode does not finish (I put some echoes in to see where the problem occurs).
Whenever a pause is involved in the print it happens,
Macro calling in the start/end gcode affect it (not the start.g and end.g)config.g:
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"RatRig 500" ; set printer name M669 K1 ; select CoreXY mode ; Wait a moment for the CAN expansion boards to start G4 S2 ; Network M552 P172.28.11.151 S1 ; enable network and set IP address M553 P255.255.255.0 ; set netmask M554 P172.28.11.1 ; set gateway M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P51.0 S0 D2 ; physical drive 121.0 goes forwards M569 P52.0 S1 D2 ; physical drive 122.0 goes forwards M569 P0.0 S0 ; physical drive 0.0 goes forwards M569 P0.1 S0 ; physical drive 0.3 goes forwards M569 P0.2 S0 ; physical drive 0.0 goes forwards M569 P0.4 S1 ; physical drive 0.3 goes forwards M569 P0.3 S1 ; physical drive 0.0 goes forwards M569 P0.5 S1 ; physical drive 0.3 goes forwards M584 X52.0 Y51.0 Z0.0:0.1:0.2 E0.4:0.3:0.5 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z800.00 E400.00:91:91 ; set steps per mm M566 X600.00 Y600.00 Z30.00 E240.00 ; set maximum instantaneous speed changes (mm/min) M203 X21000.00 Y21000.00 Z1200.00 E4500.00 ; set maximum speeds (mm/min) M201 X2500.00 Y2500.00 Z600.00 E1000.00 ; set accelerations (mm/s^2) M906 X1800 Y1800 Z1500 E650:1400:1400 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X-10 Y0 Z0 S1 ; set axis minima M208 X500 Y500 Z500 S0 ; set axis maxima ; Z-Probe M558 P1 C"0.io6.in" H2:0.6 F1200:450 T18000 A8 ; disable Z probe but set dive height, probe speed and travel speed G31 X-5 Y-20 P750 Z0.95 M557 X25:475 Y25:475 S50 ; define mesh grid M376 H10 ; Endstops M574 X1 S1 P"52.io0.in" M574 Y2 S1 P"51.io0.in" ;Bed Tilt correction M671 X-5:250:505 Y0:520:0 S25 ; position of leadscrew/bed pivot point at front left, rear middle and front right ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out1" T0 Q50 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S140 ; set temperature limit for heater 0 to 125C M570 H0 P45 T15 ; An anomaly on heater 2 must persist for 600 seconds, and must be greater or less than 20C from the setpoint, to raise a heater fault. M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out2" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S330 ; set temperature limit for heater 1 to 280C M308 S2 P"temp2" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin temp2 M950 H2 C"out3" T2 Q500 ; create bed heater output on ? and map it to sensor 2 M307 H2 B1 R0.06 D60 ; bang-bang mode for the chamber heater M141 H2 ; map heated chamber to heater 2 M143 H2 S55 ;Set max temperature for chamber M570 H2 P600 T20 ; An anomaly on heater 2 must persist for 600 seconds, and must be greater or less than 20C from the setpoint, to raise a heater fault. ; Fans M950 F0 C"out7" Q500 ; create fan 0 on pin out4 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out8" Q500 ; create fan 1 on pin out5 and set its frequency M106 P1 S1 H1 T50 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0:1 H1 F0 ; define tool 0 M567 P0 E1.0:1.0 ;Set mix ratio for tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 D0:2 H1 F0 ; define tool 1 M567 P0 E1.0:1.0 ;set mix ratio for tool 1 G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C G10 P1 X0 Y0 Z0 ;Filament Flow Detection M591 D1 P7 C"0.io3.in" L7 R75:125 E15 S0 M591 D2 P7 C"0.io2.in" L7 R75:125 E15 S0 ;Filament Detection M950 J1 C"^0.io8.in" M950 J2 C"^0.io7.in" M950 J3 C"^0.io5.in" M950 J4 C"^0.io4.in" ;Triggers M581 T2 P3:4 S0 R1 ; Miscellaneous M501 ; load saved parameters from non-volatile memory ;M911 S12 R20 ; set voltage thresholds and actions to run on power loss T0 ; select first tool
end of the printjob:
G1 X134.587 Y243.749 E.08246 M204 P3000 ; stop printing object plate.stl id:0 copy 1 G1 E-3 F2580 M107 ;TYPE:Custom ; Filament-specific end gcode echo "Print Finished1" ;M98 P"0:/macros/Machine/M_End_Gcode.g" G91 M83 G1 E-2 F2400 G1 Z10 F600 G90 G1 X10 Y500 F6000 M104 S0 M107 M140 S0 echo "Print Finished2" M2 M73 P100 R0
I commented out some parts and macro calls in the slicer.
neither of the echoes shown up in console.
both the end.g, start.g files are empty
If anyone has an idea im happy to hear -
@vBence There were some reports of print jobs not completing, but generally these were fixed in 3.5.0-rc2, see https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-RC#reprapfirmware-350-rc2-changes-since-rc1.
The file position of an executing job reported in the object model was sometimes incorrect immediately after a macro invoked by the job completed (issue 901)
SD card jobs sometimes didn't quite complete (issue 899)Can you send M122 in the console and post the response?
Can you update to the latest bug fix version here and see if you still have this problem? https://www.dropbox.com/scl/fo/wrp6hvr39vjxjlep89p5x/h?rlkey=hzka49sxnsqjpwsvy46m26ms0&dl=0Ian
I had one of these too, even if on rc3. I failed to get M122, maybe I will know more soon, but it was my first anyway. F,,,d my head and some of the print (at least is usable).
It is useful to have some anticrash sensor. I have one, but it was not enabled, and this was the result at 3am.
I found an error in z-height macro, wich I do not know how could have appear,
and also I ran a sound at part finish, both situation using a M98 to call some macro/file - do not know if related though.
The message in M122 (wich I had it but I lost it was that the printer could not home on X and Y, after print finishing). Still, why go down on Z, have no ideea, only if I will encounter this again maybe... -
@droftarts I did not send the M122 gcode after the crash, sadly i wasn't there, as soon as it appears again i can send one, also it needs a bit of repair since it broke the probes holder and the fanduct for the head. I check the new firmware with it. and also test it on my personal printer.
undefined Phaedrux marked this topic as a question
You refer to end.g being empty. Did you mean stop.g? That is the file (in the sys directory) that gets called when a print is finished.
The behavior you describe sounds like the fw is ignoring the G91 command. This is a long-shot, but maybe there's an un-printable character after the G91, making it unrecognized by RRF and skipped.
@mikeabuilder Yes i meant the stop.g my bad
For the ignoring G91 would sound logical on the Z move, but not for the XY move with it. It does it more like if it would be returning from a pause in the start of the job but the printing is already finished.
I checked the gcode and there's no character after the commands except the normal "LF" same as in the rest of the gcode
I'll update the printer's firmware soon and do some testing if the issue would appear again -
@droftarts Good news I updated to the version you sent here, and did a few prints with pauses and the issue did not came back. Also one other bug seems to went away where the z probe false triggers or not activates at all.
undefined vBence has marked this topic as solved
