    Anycubic Kobra2 heated bed with Duet3 6HC?
    • bug2k22undefined
      bug2k22
      The original controller board output has a 2 wire 'control' signal to a separate power board to control the heated bed. It looks like I can just remove this extra board and wire the power and heatbed directly to the 6HC as they both operate on the 24v psu.
      Here's a picture of the power section. Does it look correct to power it all directly from the duet board?
      • gloomyandyundefined
        gloomyandy @bug2k22
        @bug2k22 How much current does that 24V heated bed draw? Are you sure that the Duet board can supply that amount?
        bug2k22undefined 1 Reply Last reply Reply Quote 0
        • bug2k22undefined
          bug2k22 @gloomyandy
          @gloomyandy said in Anycubic Kobra2 heated bed with Duet3 6HC?:
          I am not sure, the mosfet on the power board is a WSK220N04 if that is any help. I was asking in case anyone had experience of installing on one of these larger format printers, this has a print bed of 420x420mm.
            gloomyandy @bug2k22
            @bug2k22 I'd be very cautious about using the on board MOSFET for that bed if you don't have any idea what current it can draw.
            • bug2k22undefined
              bug2k22 @gloomyandy
              Yes, I'll just run it through the existing power distribution board for the heated bed until I get it on the bench and see how much current the bed can actually draw.
                droftarts administrators @bug2k22
                @bug2k22 if you have a decent multimeter, you can measure the resistance of the bed to work out the current draw.
