Configuration of RepRap Firmware for 7 axis Robotic Arm
@AndrewStaines Robot arm Kinematics are part of the work that @JoergS5 is doing for robot kinematics/ multi axis kinematics. I am not sure if 7 axes is supported in his implementation. What is your 7th axis?
Toolpath generation is a whole different story and a big topic when we talk about using more than 3 axes for additive. There is ongoing work at various universities on this, otherwise you are left with the commercial offerings which are rather expensive.
Forward kinematics is supported in the robot kinematics, but 7 axes mean more axes than are needed for a given position + orientation (a given position and orientation need 6 axes). I. e. there are infinite solutions for the inverse kinematics (from given position + orientation calculating the stepper angles). There needs to be a preference, e.g. prefer the first axes, or take the solution with lowest velocity of all axes. This needs to be implemented. If your 7 axes robot is a Kuka IIWAR820 alike, then there are some strategies discussed in the book of Pardos-Gotor Screw Theory for Robotics, and the inverse kinematics is solvable.
@JoergS5 Thanks for the knowledge, will look into it and respond
