Frustrating level High please Help !!!
Hi , I love the duet but solving puzzles when installing a new control board is frustrating and I'm asking for help , I have two printers JGaurora a5 on one worked on the duet and now I want to arm the other with the Duet 2wifi and the most interesting thing is that I wired everything the same as in the one with the duet which runs without a problem and used the same config g . and the other does not want . The problem is that when I want to do Homing, the Z axis moves up and down and nothing more happens, moreover when I want to do the axes separately Home for each axis every time the Z axis rises and falls and the X moves a little. I checked the connections and endstops and I give up, I do not know what to do, I send a video for review.
and config G; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.3 on Mon Oct 04 2021 22:39:47 GMT+0200 (czas środkowoeuropejski letni); General preferences
M550 P"My Printer" ; set printer name
M669 K0 ; select Cartesian mode
M501; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z800.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z120.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z1000.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X300 Y300 Z260 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop; Z-Probe
M558 P5 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
link text
link text -
Check the state of the endstops with M119. It sounds like it's acting as if the endstop is already triggered at the start of the homing move. Could be wiring, crimp, etc.
@bartekp m119
Endstops - X: at min stop, Y: at min stop, Z: at min stop, Z probe: at min stop -
@bartekp LOOKS I NEED TO CHANGE THE CONNECTIONS ON ENDSTOPS OR I CAN CHANGE ON THE CONFIG G FILE
@bartekp it's better to change the end stops to normally closed, but you could invert the pin definition in your config.g by adding a
in front of the pin name. -
@oliof OK JA CHANGE THE CABLES THANK YOU FOR HELP
