Want to do a clean install on a fresh SD card, need guidance
Hello! I have worked hard to configure my Duet2 wifi printer and have it printing effectively. I have a question though.
I received this printer from someone and it had VERY old firmware on it. When I was much dumber about this, I upgraded it from a 2.x version to 3.4.4 when I was much less educated about the entire Duet3D system. Basically, I want to install the newest firmware available on a new SD card, update all of the firmware on my board, then transfer over the configs and such that make my printer run like it should. This section took me so long to figure out back in the day and I don't want to lose it.
I have a hard copy of my old firmware backed up just in case but what files need transferring from old install to fresh install so my 3D printer runs? I am assuming the config.g, bed.g, homedelta.g. Is there anything else I am missing?
See https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#sd-card-structure for a full overview of what you need besides the sys folder and main system macros (/filaments, /firmware, /macros, /menu, and /www folders, the latter with the duet web control files).
