Issues with a duet2 Wi-Fi
Cannot connect with what USB
@Blunt2007 can you still connect via WiFi?
If no, see https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-2
@oliof sometimes I can connect to the Duet web connect and other times it will not find it and it will not connect and it will also lose connection and will not be able to connect so at this time I am not able to connect to USB or connect to Wi-Fi. Wi-Fi
It would be best if we continued using your original thread
https://forum.duet3d.com/topic/34375/cannot-connect-to-duet-2-wi-fi-or-board/88?_=1708405724557
