Order Duet 3 Mainboard 6HC V1.0
I need to order a Duet 3 Mainboard 6HC V1.0 for my printer . The problem is that i cannot find this version of board. All reseller that i asked have the new version of board 1.0.2a. I've a modified firmware that are not compatible with the new board.
Where can i find this version of board?
Thanks -
@DanielP you would have to buy one second hand. Whats stopping you making the same modifications for the 1.0.2?
@DanielP We might have a refurbished 6HC v1.0 in stock. if you email sales@duet3d.com they can check.
@jay_s_uk I've a modified firmware that are compatible only with the v1.0. I would like to avoid of doing a porting to the new version. I thought that as manufacturers you have some old boards in stock
@DanielP I don't work for Duet3D. At least Tony said above they might have some refurbished units in stock.
Theres also a v1.0 on ebay at the moment https://www.ebay.co.uk/itm/395166765180 -
@jay_s_uk Thanks, i will try
