How to turn off heaters?
Morning All,
Just trying to tidy up some of my gcode start and end scripts and have come to trying to sort out the shut down process at the end of a build.
On DWC you can click on the heater to cycle between Off, Standby, and On. How do you shutdown a running heater to the Off state with gcode? I've got a minimum temperature set which is used to check obvious temp sensor errors, so setting the temp to -273 results in an error.
Thanks.
@DocTrucker look at the new M568. That's what I use
@jay_s_uk cheers. Missed the obsoletion notice on the old one.
Will be interwsting to see which command Super Slicer & Orca Slicer use.
M0 may be?
@DocTrucker superslicer and orca still use the old M109 commands etc
