btncmd panel lost after IP change
So my btncmd panels are gone in DWC after duet wifi IP change. Is it an issue with the IP change? All of my called macros are still in my macro folder. I dunno why the IP changed, I did not change it on my end...
M115 FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.4.5 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2022-11-30 19:41:16
@wayneosdias basically, all the settings are stored locally in your browser, not on the duet, so when the ip address changes, so does the cache of where the settings are stored.
so hopefully you have a backup of your layout!
if you don't, change your settings in M587 to get the ip address you had previously.
then backup your settings and make use of the auto restore setting just in case the ip address changes or you log in from another device. https://github.com/MintyTrebor/BtnCmd/wiki/Auto-Restore -
@jay_s_uk Thanks! Ill give it try
