Is the 3HC expansion board also compatible with 6XD
I would like to connect 3 easy integrated servos to a 6XD board for a big delta. But i also need to control 2 to 3 steppers on the extruder. Can i connect a 3HC board to the 6XD. The documentation says its only compatible with 6HC and the duet mini 5+
@lazy_mosquito yes you can connect a 3HC to a 6XD.
Can you confirm in the docs where it says what it's compatible with so @droftarts can correct it? -
@jay_s_uk Thanks for the swift reply. On the following page in the connectivity part it states only the 6HC and the mini 5+:
https://www.duet3d.com/duet3expansion3hc -
@lazy_mosquito thanks for pointing that out. I'm sure the duet guys will update the info. In the mean time feel free to connect a 3HC to a 6XD
@lazy_mosquito thanks, I think it would help if we changed all Duet 3 CAN-FD expansion board documentation to state that they are compatible with all Duet 3 mainboards. leaving this here if anyone else searches the forums for this question.
