Can I edit Gcode in DWC
Hi all. I need to edit a very very large file to recover a failed print but the "edit file" is greyed out in DWC. Can it be done? Any suggestions? Ponterface struggles.
@damaged_goods DWC has a size limit for G-code files. If that option is greyed out, your file is probably too large. Consider downloading it and edit it using Notepad or another editor of your choice, then upload it again.
@chrishamm thank you
What is the size limit for g code files in dwc
