Right way for starting script?
Hi Doug
That´s interesting!! I am not at my printer until tomorrow so have to test that then. But do you have some homing cycle first (in the start script)? Before the G32.. I dont want my extruder, with printing distance to the bed, heating up to 240c and then start printing..My bed.g file has the home in it and then the autocal routines so it is all in the macro.
I have various settings in my S3D Profile for different temps and materials which negates the need to have the temps in the start script I slice using the profile settings I want it waits till first layer temps are reached then runs my Start script and the G32 calls Bed.g macro.
HTH
Doug
That's right but if you want to move to a specific position before heating like an ooze bucket as I used to have then you can move in the script but S3D does the heating always before your script is executed.
Using those variables disables the automatic heating and you can place it yourself where you want in the startup procedure and do a move first or leveling before heating to the final print temperature…
