Right way for starting script?
@Alex9779 After reading the link you posted I dont quite understand how to make S3D first heat up bed and extruder (using the starting script temperature), then do the probing of the bed, and then take the temperatures from the "printing object" file and start printing the object.
What would the gcode look if I liked to heat up bed and extruder to 50 (bed) & 150 (extruder) do the probing and then start printing with the bed to (60) and extruder to (240) and use the temperatures from the slicer settings (S3D)? If its possible?
Sorry but dont understand using varible?! -
I have found that S3D actually does the start script after the heating cycle and mine has just G32 in the script so when I run a print the bed heats then the hotend then my start script then the rest of the print is executed!
Doug
Hi Doug
That´s interesting!! I am not at my printer until tomorrow so have to test that then. But do you have some homing cycle first (in the start script)? Before the G32.. I dont want my extruder, with printing distance to the bed, heating up to 240c and then start printing.. -
Sorry but dont understand using varible?!M190 S50
M109 S150
G32
M190 S[bed0_temperature]
M109 S[extruder0_temperature] -
Okey, thanks a lot!
With this I specify the printing temp for the "printing file" witch overrides the settings in the slicer?! -
I don't understand the question, sorry. With this you start with heating. Then the bed is probed. When that's finished the head stay at the last probe position and the bed is heated to the temp you set in the temperature tab. Then the same happens for the extruder.
If you want to do the final heating somewhere else insert a G1 command after G32. -
Ok sorry for being unclear.
When you say "temperature tab" do you mean the settings in S3D? -
Yes that's the whole point of using variables in the script. That way you don't have to change the script every time. It takes the values for the specified heater on layer 1. Each heater has an assigned number normally starting with 0 also on the temp tab. That is the number in the variable…
Hi Doug
That´s interesting!! I am not at my printer until tomorrow so have to test that then. But do you have some homing cycle first (in the start script)? Before the G32.. I dont want my extruder, with printing distance to the bed, heating up to 240c and then start printing..My bed.g file has the home in it and then the autocal routines so it is all in the macro.
I have various settings in my S3D Profile for different temps and materials which negates the need to have the temps in the start script I slice using the profile settings I want it waits till first layer temps are reached then runs my Start script and the G32 calls Bed.g macro.
HTH
Doug
That's right but if you want to move to a specific position before heating like an ooze bucket as I used to have then you can move in the script but S3D does the heating always before your script is executed.
Using those variables disables the automatic heating and you can place it yourself where you want in the startup procedure and do a move first or leveling before heating to the final print temperature…
