Bedmesh question
Hello, I have a question about understanding.
M122 shows me the following: "=== Move ===DMs created 83, segments created 9, maxWait 57062ms, bed compensation in use: mesh, comp offset 0.000"
Does this mean the bedmesh is loaded and active but not compensating? If so, why is there no compensation? The background is that I can see from my prints that I have no mesh compensation. Thank you very much and have a nice day. -
means that the mesh is applied. Whether it's accurate depends on a few other things.
What does your mesh look like in the display?
What does a test print over the full bed surface look like?
Please share some more information, like your config.g, your homing files, bed.g, mesh.g, your slicer start gcode. Also the results of sending M122 and M98 P"config.g"
@Phaedrux , thank you. The problem was in front of the printer erverythings works fine.
