More Accelerometer questions
Am I right in thinking that the accelerometer is not intended to be mounted all the time?
If that is the case when should it be mounted? Does the input shaping need to be repeated?
I'm going to use it on my home built corexy is there a place I can get gcode for performing the input shaping?
Again, thanks in advance.
You only need to mount it when you take a measurement.
@Phaedrux Many thanks
