Toolboard 1LC: some things work other won't
<sigh> Nice board..
I have some problems commissioning the board though. I can get fans and the hotend working properly, but the stepper motor remains de-energized and the endstops don't work, but first the details: v1.3 toolboard and duet3 mini5+.
M574 X1 S1 P"0.io1.in"
Works just fine:
10/24/2023, 4:20:14 PM m574 Endstop configuration: X: low end switch connected to pin io1.in Y: low end switch connected to pin io0.in Z: low end Z probe
M574 X1 S1 P"121.io2.in"
will result in this error:
10/24/2023, 3:47:54 PM m574 x1 s1 p"121.io2.in" Error: M574: Response timeout: CAN addr 121, req type 6057, RID=19
and then M119 reports no endstop found:
10/24/2023, 4:07:31 PM m119 Endstops - X: no endstop, Y: not stopped, Z: not stopped, Z probe: at min stop
and, is verified as such with:
10/24/2023, 4:13:14 PM m574 Endstop configuration: X: none Y: low end switch connected to pin io0.in Z: low end Z probe```
And the toolboard is there... M122 B121
10/24/2023, 4:17:14 PM m122 b121 Diagnostics for board 121: Duet TOOL1LC rev 1.1 or later firmware version 3.4.6 (2023-07-21 14:17:33) Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25) All averaging filters OK Never used RAM 2596, free system stack 88 words Tasks: Move(notifyWait,0.0%,155) HEAT(notifyWait,0.4%,111) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,3.0%,57) MAIN(running,91.7%,351) IDLE(ready,0.0%,26) AIN(delaying,4.9%,142), total 100.0% Last reset 00:04:18 ago, cause: software Last software reset data not available Driver 0: pos 0, 657.7 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 24, reads 63917, writes 14, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter -3/10, peak Rx sync delay 214, resyncs 0/0, no step interrupt scheduled VIN voltage: min 24.2, current 24.2, max 24.2 MCU temperature: min 37.5C, current 38.0C, max 38.0C Last sensors broadcast 0x00000002 found 1 224 ticks ago, 0 ordering errs, loop time 1 CAN messages queued 5130, send timeouts 0, received 2328, lost 0, free buffers 37, min 37, error reg 110000 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 Accelerometer: LIS3DH, status: 00 I2C bus errors 0, naks 3, other errors 0de_text
Did I miss setting something, or a jumper?
TomW
@TomW what firmware version are you running on the mainboard?
What's your wiring like between the two? -
@jay_s_uk said in Toolboard 1LC: some things work other won't:
What's your wiring like between the two?TIA
The Duet3 Mini5+ has an SBC (RPi3 running Raspbian GNU/Linux 10 (buster)).
Duet3 is:
10/25/2023, 12:12:35 PM m115 FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.5.0-rc.1 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2023-08-31 16:16:56
and Toolboard:
10/25/2023, 12:13:24 PM m115 b20 Duet TOOL1LC rev 1.1 or later firmware version 3.4.6 (2023-07-21 14:17:33)
Toolboard wiring is 18ga onto 24v supply over a 1.5 meter length. The CAN bus is wired using 22AWG pair that I've twisted about 1 turn per inch.
This may be helpful?
10/25/2023, 12:18:17 PM m122 b20 Diagnostics for board 20: Duet TOOL1LC rev 1.1 or later firmware version 3.4.6 (2023-07-21 14:17:33) Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25) All averaging filters OK Never used RAM 2596, free system stack 88 words Tasks: Move(notifyWait,0.1%,155) HEAT(notifyWait,29.3%,95) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.8%,76) CanClock(notifyWait,1.2%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,210.1%,57) MAIN(running,143.0%,351) IDLE(ready,0.0%,26) AIN(delaying,341.1%,142), total 725.6% Last reset 17:45:08 ago, cause: software Last software reset data not available Driver 0: pos 0, 657.7 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 38, reads 38029, writes 14, timeouts 5, DMA errors 0, CC errors 0, failedOp 0x6f, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter -5/11, peak Rx sync delay 219, resyncs 0/0, no step interrupt scheduled VIN voltage: min 24.2, current 24.2, max 24.2 MCU temperature: min 31.9C, current 34.2C, max 36.3C Last sensors broadcast 0x00000002 found 1 241 ticks ago, 0 ordering errs, loop time 1 CAN messages queued 1278079, send timeouts 0, received 575145, lost 0, free buffers 37, min 37, error reg 110000 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 Accelerometer: LIS3DH, status: 00 I2C bus errors 0, naks 3, other errors 0
I have run an M303 against the toolboard, with expected results. I can control fans, pin-test-cycle the BLT pin (M280 P"20.io0.out" S120 I1) and it does the 10cycle pin-drop okay. What doesn't work is inputs of any kind, endstop or BLT.
@TomW you need to update your toolboard firmware as you have a mismatch and that's more than likely causing the errors
M997 b20 should do it -
It appears that there was no change.
10/25/2023, 1:06:53 PM m115 b20 Duet TOOL1LC rev 1.1 or later firmware version 3.4.6 (2023-07-21 14:17:33) 10/25/2023, 1:06:22 PM m997 b20 Board 20 starting firmware update 10/25/2023, 1:02:12 PM m115 b20 Duet TOOL1LC rev 1.1 or later firmware version 3.4.6 (2023-07-21 14:17:33)
I was confused by the instructions here to upload a toolchain file, see section: "Updating the firmware"? I did download a Duet3Firmware_TOOL1LC.bin, and placed it into ./opt/dsf/sd/firmware/
Then I puzzled my way through: Updating the bootloader on Duet 3 expansion and tool boards.
Maybe I should wipe everything and start over?
@TomW try sending
sudo apt update && sudo apt upgrade -y
Then try to update of the firmware again -
nm, I borked the duet3 binary, lost contact with the mini5+, looks like I'll have to a fresh installation.. <sigh>
@TomW managed to get sorted?
Heh, yes, it is working as expected. I did a full reload of everything and now everything is working.
I do like the resident bootloader (permanent) that resides in the Mini5+, reminds me of a project that I did 15 years ago. Nice work!
73 TomW
