Question about tool Z offset
I finally have the tools (well 2 anyway) mounted and wired on my E3D MS/TC setup.
I'm getting the tool offsets configured.
So consider this scenario:
- after homing no tool is mounted
- the Dashboard displays the Z position as 10 which is where the Z homing code "parks" it
- issue T0 and a tool is mounted which has a Z offset of +20
- the Dashboard now displays the Z position as -10 which is correct based on the tool Z offset
Clearly the Z position needs to be changed before the tool can be moved into position for printing.
I was kind of expecting the firmware would keep Z at 10 by moving it based on the tool Z offset, mostly because the firmware already does some "automatic" control of the tool heater(s).
It seems I was wrong in my expectations, so it's up to my code to take care of that OR is something configured wrong?
Thanks much.
