Nozzle detach the part - Chiron Duet 2 wifi
@dc42 Where have I to put the positive and the negative tips? Can you describe it more precisely?
I follow the Teaching Techs guide here:https://teachingtechyt.github.io/calibration.html#intro (This one not jet
https://docs.duet3d.com/en/How_to_guides/Calibration ) and the tests are all good.Now I'm printing something bigger and this what is happening:
This is the g.code I'm using https://we.tl/t-33Er3mvoe0
What do you think? Is that a problem of speed, temperature, cooling, retraction or adhesion?To be more coplete I post also the picture of the tests
It still looks like over extrusion to me. Try reducing the extrusion factor to 90 or 95% and see if it helps.
@Phaedrux
Z Seam Alignment: Sharpest corner
Flow: 100%
Results:
Z Seam Alignment: Random
Flow: 95%
Results:Furthermore I saw that this component (in the following picture) is broke. Where can I buy it?
