PanelDue Logo Firmware Compiler, Testers needed
since i always want to see my Logo at Startup, i needed to compile each new
PanelDue Firmware to include a Logo, to ease up the process i created a
Tool to do everything on it's own.
The Old Standard Operation: https://www.instructables.com/How-to-Add-a-Splash-Screen-to-PanelDue/Now: I need You to test the Software extensively and give me Feedback what to change and what to improve on it!
Google Drive Link for Download .rar file
after Installation, make sure to run the Program as Administrator (Permission to Save your Work Paths via the Options Tab)Please left your thoughts
BR
Sebastian -
I did try it. Look´s fine but I am not able to use paneldue logos from some time ago....neither manual way neither with your app
@apak can you share these logos? as far as i learned during my experience with programming this software the .bmp file should be exactly 800x480 pixels and not greater than around 3mb...
@NeueKlasse MY BAD, i double checked my bmp files to note that in some point I changed the size to 800x488 pixels, and it didn´t work out as expected....
Doing it wrong for some time, you force me to double check the whole process.
Your app worked as expected.
I would love it to be portable, as I run everything 3d related from a NAS shared folder on several computers....so no need to installed it on everyone of them
@apak Great that it worked out for you!
I Uploaded a Potential "Portable" Version for it,
(it is the Preparation Folder for the "Inno Setup Compiler", but can be used without installation...)
Basically with the Portable .ZIP Archive, Unzip it and if you let the Files stay together (in the Folder) and start the .exe, it should work as expected
https://drive.google.com/file/d/1h8VFJc-2HVDe2m1Smub98zgmQutajNtW/view?usp=drive_link -
This post is deleted! -
not working on a windows 11 pc, no logo attached...
@NeueKlasse Thank you for making this tool. I gave it a try on my windows machine. The splash screen appears plain white for about 1/2 second and I don't see the BMP image. Files are attached. Can you give it a shot and see if it works on your machine?
I'm loading this to a paneldue 7i. I'm using PanelDueFirmware-3.4.1-7.0i and splash.bmp as the input in the attached zip folder. PanelDueFirmware3.bin is the output.
@dc42 Can we please add .bmp as a valid file type for attachments in this forum? I see .bmb listed below. Maybe it's a typo. I tried uploading a .bmp file and it gave me the error below.
[files.zip](Invalid file type. Allowed types are: .png, .jpg, .gif, .bmb, .pdf, .svg, .dxf, .cad, .txt, .doc, .xls, .docx, .xlsx, .stl, .csv, .g, .gcode, .stp, .step, .cps, .cbpp, .odt, .ods, .json, .scad, .heic, .cpp, .c, .h, .py, .fcstd, .elf, .bin, .mp4, .jpeg, .hpp, .webp, .heic, .js, .qoi, .gc, .pcapng, .3mf)
PanelDueFirmware3.bin PanelDueFirmware-3.4.1-7.0i.bin
