Panel due 5i multiple axis visibility
Hi in my machine I use following axis
X,Y,Z,U,V,W,A and 4 extruders
In panel due I can only see upto W axis, A is not visible. In web interface it is showing A axis.! What should I do?
IMG_20230807_143550_1~2.jpg -
Firmware versions?
@adhanabal Panel due firmware version is PanelDue-3.4.1
Duet 3 mainboard firmware version is 3.3 -
I suggest you update your firmwards and re-check that it's the same situation. But it may just be a limitation of the panel size and paneldue hardware itself.
https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.6
https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.5.0-rc3
@Phaedrux okay I'll check that tmw
