while-loop to track temperature
@Jojo-0 ah yes, store it in a variable at the start of the print and then use that variable throughout the print?
Parsing the filename to remove the directory section is not going to be something we can implement in 3.5 so we need a solution to work around that for now.
@T3P3Tony
Just fpound a way to write it into a c-file stored beneath the job with the same name.
So I can transfer it afterward into a excel file.echo >>{job.file.fileName}^".c" {state....
@T3P3Tony Is there any possibility to also write the target temperature the nozzle or bed should reach? As example sth like activated temperature?
My goal is to compare the target temperature with the current afterwards.
@Jojo-0 check the OM I think there is the set temperature for each tool.
@T3P3Tony
okay, thank you.
I'll search there.
