Cable Lenght
Hello ,
what is the maximum cable length between Rapberry Pi and the Duet 6xd Borad
@Zseven The supplied cable is 150mm is length so not much more than that.
They used to supply 200mm cables but they had issues with interference -
Ok thanks ,
this is a problem because the PanelDue also has mad 300mm of cable length.
However, there are 1000mm from the cabinet to the display.
Is there a solution? -
@Zseven you can run a paneldue with a lot longer 4 wire cable than 300mm. I have one with a 2m shielded cable and that runs fine. Of course using the 4 wire cable would mean you wouldn't be able to use the onboard sd card slot in the paneldue but you could use a USB port in the Pi instead.
You could of course also use a HDMI display connected to the Pi which could have a very long cable length. -
But on a HDMI display only the DWC runs and not the Panel Due software or ?
@Zseven correct, only DWC runs.
You could also look at DueUI https://forum.duet3d.com/topic/32740/dueui-release-v3-5-0-beta1-is-now-available?_=1687932250675
