Solved New Cartesean Machine Stepper Motor Testing
Greetings
Currently Stepper Motor are being tested for the New Cartesean Machine we are building via YAT Terminal.
While testing the X Axis Stepper Motor have pressed the Emergency Push Button, from then the stepper motors re not responding. Hence I have closed the YAT Terminal and have shutdown the Powersupply to Duet 3D Mainboard 6HC and again started testing.
This time Y and Z Axis Stepper Motor are working fine. The X Axis Motor is still not working. I Have checked the X Axis stepper motor, it is working fine.
How to make the X Axis stepper motor connected to driver 0 to normalize? Requesting your insights plz.........
What was happening when you pressed emergency stop?
Have you tested a different motor on the X axis driver?
@Phaedrux Hi,
The X Axis Stepper Motor is being tested when the Emergency Push Button is pressed.
The Y And Z Axis Motor were working fine after the EPB usage.
Since the Other Axes were having multiple motors i was not able to test them with X Axis driver.
However after a brief time with a shutdown and restart the X Axis was working fine.
