12864 Laser Menu System?
H All,
Is anyone aware of a pre-configured 12864 Menu system for a Laser?Have done some googling and not fond anything so fa...
Any thoughts wold be much appreciated.
Many Thanks
Barry M -
@CNCModeller I don't think there is one yet. If you want to, you can use the configtool to design a custom menu system.
@chrishamm said in 12864 Laser Menu System?:
Thanks @chrishamm I had a quick look at the config tool on my mobile but didn't notice anywhere to design a 12864 menu system. Am I missing something obvious?
Many thanks
Barry M -
@CNCModeller You need to select either Duet 2 Maestro or Duet 3 Mini 5+ to see the Display page. I wouldn't recommend using the configtool on a mobile device, though.
@chrishamm thanks, yeah won't be designing on mobile, just having breakfast at the cafe so had a quick mooch...
I'm actually using it on a Duet2 WiFi with a custom cable. I'd suggest the display is enabled for thos too with a note about the cable and a ref to the wiki.
Many thanks
Barry M -
@chrishamm is there any way to preload the config tool with an existing menu system?
@CNCModeller Menu files can be added only via copy&paste but icons etc. are automatically converted from standard image format (JPG, PNG etc). If you save the configtool template, the menu files should be properly restored the next time you edit it.
