[REQUEST] Smooth Bed Mesh Movements
I've recently been printing a large part that takes up most of my printer's bed. I've noticed that the bed mesh (due to a rather uneven, unadjustable bed) causes fast print moves (200mm/s) with sudden stop-starts along its trajectory, most likely as the z-motor cannot keep up with the requirement for the mesh bed.
It would be nice to have the option to turn on the mesh bed in a print with a smooth mesh bed which will calculate the maximum speed a move can be made and adjust the requested speed accordingly so the motion will be smooth instead of jerky.
This could either be implemented as a separate command (G29 S5) or have the mesh bed compensation updated to use this. My concern for implementation is the required computation of such calculations and if they'd be substantial enough to exceed the capabilities of the processor (for reference I am running a Duet 2 Wifi).
I understand using something like glass or a MIC6 bed would essentially solve this problem, but that can be expensive.
Thoughts?
@Merlin246 said in [REQUEST] Smooth Bed Mesh Movements:
Your Z axis jerk value is probably too low. This is a common side effect.
