Advice on Calibrating on Cura 5
Board: Duet Wifi
Core XY
Slicer: Cura 5.XXEDIT: all defaults, except temp to 240, PETG (already ran a temp tower. Has the same issue with blobs on PLA)
I'm getting these blobs on the corners while printing a retract tower.
The nozzle seems to just sit there and extrude then start traveling.
from reading around, it seems to be a issue with cura 5.xx the way it handles power recovery...
AFAIK, the duet 2/wifi doesn't have the feature.
On a whim I've ran the command to disable it, and no change.Any ideas? Thanks
You'd have to share your config.g and your cura settings to give us any hope of telling what may be wrong.
