Can Bossa connect to a running duet2 wifi board?
I'm about to migrate from RRF2 to RRF3 and wanted to test all the utilities needed before I bricked my Duet2 Wifi. While Yat is able to connect through my usb cable, Bossa is not. When I select the com port my Duet2 is connected to I get a message back saying Bossa could not connect to the device. For informational purposes I did install the Duet driver for that com port before I tried any of this.
I've programmed a lot of devices in my career where some need the board to be in "reset" for the programmer to work and others don't. Is the Atmel on the board one of those that need to be in "reset"?Thanks!
@rtuinila yes. It needs to be erased to go into bossa mode
Thanks for the reply!
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
