Marlin compatibility
Can reprap run cnc gcode interpreted for marlin? From the reading I've done just accel and jerk adjustments are left out.
@breed it can run Gcode meant for Marlin when M555 is set. See https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m555-set-compatibility
However, configuration gcodes in config.g are RepRapFirmware specific. Generally the same Gcode is used, but RRF uses mm per minute whereas Marlin uses mm per second. For a guide, see https://docs.duet3d.com/en/User_manual/Overview/Adapting#going-from-marlin-on-arduino-to-reprapfirmware-on-duetIan
@droftarts thank you very much.
