IDEX Head crash when doing G29 with U axis
@kuon Can it be that he makes t1 inactive after confirming, or even automatically switches to t0?
@Proschi78 No, because if I select
T1
before doingG29
it works. -
@kuon Yes I read that. But if t1 is not selected before the g29 command, does it then switch to t0 or become inactive after the first acknowledge ?
@Proschi78 No,
G29
doesn't affect selected tool. -
@kuon do you have a mesh.g ?
@Proschi78 No.
mesh.g
doesn't exist. -
@kuon I think if there is a mesh.g where the tool is called first, the g29 command will work
@kuon did it work now
@Proschi78 As I said, if I select the tool before doing
G29
so,T1 + G29
it works. But I think it should work withoutT1
as I specifiedU
axis inM557
. Also it should not go crash in other tool. Perhaps @dc42 can chime in. I'd be happy to try to help debug the issue. -
This post is deleted!
