Printer stops sporadically and then no longer responds
Unfortunately, the printer is currently out of order due to various modifications.
These lines were entered in the config for the sensor
“M955 P0 C “spi.cs3+spi.cs2” I16”
“M593 P “zvd” F45”This was an external sensor that was connected to the temp daughterboard connector
The mainboard is a 6HC V1.01
I also have the same sensor running on a modified Ender with RepRap and it doesn't cause any problems there.
@michaxy What is the sensor? Only LIS2DW12, LIS3DH and LIS3DSH are supported, ADXL345 is not supported.
I would guess that your wiring is incorrect or is picking up interference. I have updated the wiring guide since last year, please check yours if you have a supported accelerometer: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_Accelerometer#wiring
It was a LIS3DH, but that doesn't matter now, because it will no longer be used, a Roto-Toolboard is currently installed, but not yet fully connected, which should then work without any problems .
But I will check the wiring from the LIS3DH again later, just to know if it was this one.
