Bed heater 2 - not responding on Panel Due - working from DWC.
I am having a problem with Paneldue control of the second bed heater (outer zone) of my print bed.
Both bed heaters are showing on Paneldue - but I can only change the settings for the first bed heater and the hot-end heater. When I try to change the settings for the Zone2 bed heater - it just resets to 0 and does not change them. Curiously, it works from DWC without problems, but my computer is in a completely different room, so it would be convenient to have the option to change both heaters on the spot from PanelDue.Duet firmware : 3.4.1
DWC : 3.4.1
PanelDue firmware : 3.4.1Here is the part of my config.g related to heaters and thermistors, maybe I'm doing something wrong :
; BED - ZONE 01 HEATER (CENTER) M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 A97.3 C230.7 D2.8 S1.00 V24.2 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 P0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M570 H0 S200 ; Set maximum heating time (Snnn, in seconds). ; BED - ZONE 02 HEATER (EDGE) M308 S2 P"e1temp" Y"thermistor" T100000 B3950 ; configure sensor 2 as thermistor on pin e1temp M950 H2 C"e1heat" T2 ; create bed heater output on bedheat and map it to sensor 0 M307 H2 B1 S1.00 A166.8 C910.6 D2.8 V24.2 ; enable bang-bang mode for the bed heater and set PWM limit M140 H2 P1 ; map heated bed to heater 1 M143 H2 S120 ; set temperature limit for heater 0 to 120C M570 H2 S200 ; Set maximum heating time (Snnn, in seconds). ; MOSQUITO MAGNUM HEATER & THERMISTOR M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 R2.531 K0.649:0.000 D4.51 E1.35 S1.00 B0 V24.1 ; disable bang-bang mode for heater and set PWM limit ; CHAMBER THERMISTOR M308 S3 P"exp.thermistor3" Y"thermistor" T100000 B9350 A"CHAMBER"
And here is the Photo of the PanelDue7 screen :
Consider updating your firmware to 3.4.5 and make sure you're actually on the latest PanelDue firmware.
@Phaedrux Thank you for the reply.
My PanelDue firmware is indeed the newest (3.4.1), checked.
I've gone through all the changelogs from 3.4.1 (my version) to 3.4.5 - and as far as I could see, there were no changes related to PanelDue, nor any other changes that were relevant to me, so that is why I hesitated to update (risk breaking something else that works).If you think updating to 3.4.5 could solve the problem, I will try.
Maybe something in my Config.g is not right?
@Phaedrux Updated firmware to 3.4.5 - the problem is still there. Second bed heater cannot be controlled via PanelDue. It shows the correct temperature, I can click on the buttons - even activate (turns red) the second bed heater, but it does not allow me to change the temperature - when I set any temperature it just reverts to 0. PanelDue firmware is 3.4.1 which I believe is the latest. If anyone clhas an idea of what the problem might be - please advise. I suspect it may be somethingnin my config.g (the way heaters are defined), but I cannot figure it out.
Just a bump to see if anyone has any idea on how to solve this?
I am sure there are people with multiple bed heaters and PanelDue.....
Thanks! -
@omni sounds like this issue.. hm?
@omni please provide your full configuration so i can try to reproduce the problem. Thanks.
undefined mfs12 marked this topic as a question
@mfs12
Thanks for the reply!
Yup, seems like it's the same problem.
Here is a video of it in action :
https://streamable.com/tex6flAnd here is the complete Config.G :
; GENERAL G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"ARIES" ; set printer name ; NETWORK M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; PANEL DUE SERIAL PORT M575 P1 S1 B57600 ; DRIVES M569 P0 S0 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M569 P4 S1 ; physical drive 4 goes forwards M584 X0 Y1 Z2:4 E3 ; set drive mapping - DUAL Z M350 X16 Y16 Z16:16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z1600.00 E415.00 ; set steps per mm M566 X400.00 Y400.00 Z0 E120.00 ; set maximum instantaneous speed changes (mm/min) JERK M203 X12000.00 Y12000.00 Z900.00 E1200.00 ; set maximum speeds (mm/min) M201 X800.00 Y400.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X1400 Y1400 Z1200 E800 I50 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; DUAL Z M671 X20:460 Y250:250 S5.0 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis ; AXIS LIMITS M208 X0:504 Y0:500 Z-1:400 ; ENDSTOPS M574 X1 S1 P"!^xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"!^ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-PROBE M574 Z0 C"nil" ; no Z endstop switch, free up Z endstop input ;M558 P8 C"!zprobe.in" H5 F1200 T12000 R0.5 A4 S0.05 ; PIEZO - P8 unfiltered, P5 filtered, P8 is faster M558 P9 C"^zprobe.in" H5 F300 T10000 A10 S0.03 R0.3 ; BLTOUCH M950 S0 C"exp.heater3" ;G31 P100 X0 Y0 Z-0.09 ; PIEZO OFFSET G31 P100 X-22 Y0 Z2.690 ; BLTOUCH OFFSET M557 X30:480 Y30:480 S75 ; define mesh grid ; BED - ZONE 01 HEATER (CENTER) M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 A97.3 C230.7 D2.8 S1.00 V24.2 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 P0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M570 H0 S200 ; Set maximum heating time (Snnn, in seconds). ; BED - ZONE 02 HEATER (EDGE) M308 S2 P"e1temp" Y"thermistor" T100000 B3950 ; configure sensor 2 as thermistor on pin e1temp M950 H2 C"e1heat" T2 ; create bed heater output on bedheat and map it to sensor 0 M307 H2 B1 S1.00 A166.8 C910.6 D2.8 V24.2 ; enable bang-bang mode for the bed heater and set PWM limit M140 H2 P1 ; map heated bed to heater 1 M143 H2 S120 ; set temperature limit for heater 0 to 120C M570 H2 S200 ; Set maximum heating time (Snnn, in seconds). ; MOSQUITO MAGNUM HEATER & THERMISTOR M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 R2.531 K0.649:0.000 D4.51 E1.35 S1.00 B0 V24.1 ; disable bang-bang mode for heater and set PWM limit ; CHAMBER THERMISTOR M308 S3 P"exp.thermistor3" Y"thermistor" T100000 B9350 A"CHAMBER" ; FILAMENT SENSORS ;M591 D0 P7 C"^e0stop" L7 R50:250 E22 S1 ; pulse, disabled, 7 mm/pulse, measure every 22 sec M591 D0 P5 C"e0_stop" R40:1200 E3.0 S0 ; DUET laser filament sensor ; FANS M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off ; TOOLS M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; ACCELEROMETER M955 P0 C"spi.cs4+spi.cs3" M593 P"zvddd" F52.2 ; use ZVD input shaping to cancel ringing at 37.6Hz ; MISCELLANIOUS T0 ; select first tool M572 D0 S0.07 ; PRESSURE ADVANCE M98 P"startup.g"
undefined mfs12 has marked this topic as solved
@mfs12 Just checking to see if there is any update on this, since I see it has been marked as solved? Thanks
@omni I would suggest this commit has fixed it and that'll be included whenever the next build is
fix will be released with the next version.
@mfs12 Thank you. Looking forward to the release.
