Duet 2 Wifi Module Connection Problem
I have had a duet 2 wifi board installed in my ender 3 pro for a few months now and everything has been great. Yesterday I turned it on and it never connected to its normal IP. So I moved it to the work bench, and was able to connect to the board through serial tools. The wifi module was disabled, so I sent M552 S1 and it connected to my internet and its normal IP. I unplugged it from the usb, reconnected the power cord, and started it up...... and still not connecting. I did notice the fan I installed to blow some air over the mainboard stayed on. I have it set it so no fans are on initially until a certain temp. Its almost like the board is stuck in its start up process or something. Anything idea? Thank you in advance for your time and help!
@slabstations try a replacement SD card, sounds like its not reading the SD card on startup.
