How to fix LED behaviour, data not going through CAN
I have Duet 3 Expansion 1XD connected to Duet 3 Mainboard 6HC.DWC wasn't recognising the 1XD, I thought i has something to do with can address, so I have tried to reset the 1XD to factory setting with jumper. But i don't think it got reset as during the process, I got LED behaviour and error codes - 4 times flesh.
The power of the main board is fine, and the status LED on the main board works, flashing per second. I think the CAN connection between the main board and the expansion board is ok as well. This is RJ11 I am using. it is not the High-Speed ADSL cables but i read this is not a problem. When I tested it with a cable test, it worked.
when I restarted the board without the jumper , status LED on the 1XD was flashing continuously and rapidly. DWC doesn't recognised 1XD.
What can i do to fix this?
undefined T3P3Tony referenced this topic
@Sophiechka lets keep this to one topic:
https://forum.duet3d.com/topic/31856/help-in-errors-between-duet-3-6hc-1xd/2?_=1679403876121
undefined T3P3Tony locked this topic
