Duet 3 Mini 5+ customizable schematic
Hi. Is there a customizable schematic for the Duet 3 Mini 5+? I am using the duet for a bachelor thesis, and need to make a schematic with other components and it would be really nice to not have to make one from scratch. It would really help with a file that works with Autodesk Eagle, but any other program can work as well.
@luxirius Duet boards are designed in KiCAD (open source), and are available (open source) from our Github repository, for example here: https://github.com/Duet3D/Duet3-Mini5plus/tree/main/v1.01/Duet3_5%2B_Wifi_v1.01_KiCAD
We don't have versions that are compatible with Eagle (closed source). But there's probably some way to export them from KiCAD to Eagle.Ian
@luxirius As @droftarts said, the KiCAD source is there. I do not know of a good import to Eagle from KicAD, especially not the Eagle got bought by autodesk. I suggest you use KiCAD for this. and don't forget to publish your source from your project as well (see the terms of the license agreement ).
