Emergency Stop permanent not only trigger
i wired a emergency stop and connected it to a free input (24V, normally closed). It is working but i want it to be more than just a trigger. As long as the button is pushed i dont wont the printer to run. Right now i can reset the printer although the button is still pushed.
Is this possible?Duet3 6HC
M950 J4 C"io4.in"
M581 P4 T0 S0 R0Greetings
Frosch -
@Froschkönig The simplest way is to use a true emergency stop switch and wire the PSU positive through it - that's what do. So when I hit the button, it kills all power to the printer until I reset the switch.
