Lets see your time lapses!
I am keen to see some time lapses captured on Duet controlled machines, either using DuetLapse3 or otherwise. Please post a reply to a link to the video (on youtube or wherever you host them). Also would be great if you put a few details about your setup for capturing them.
Thanks!
Layer synchronized time lapse print on UMMD.
I used a cell phone camera running Open Camera, triggered by a bluetooth button. At each layer change, custom gcode moves the extruder to X=0 (center of the X axis), then Y axis moves to the back of the machine which pushes the bluetooth button. Images are uploaded to Google Photos, and I use IrfanView to bulk crop to desired size and ImageJ to turn image sequence into video. Details here.
Are there any particular characteristics you are interested in: successful prints , failures (I can always conjure up one of those), duration, fps, image resolution, etc. ?
I'm more than happy to "lapse-to-order"Ender 5 pro, Pi Camera, DuetLapse3
@stuartofmt initially I was just interested to see whats out there! I will write a bit more about a collaboration we have in a few days.
Thanks!
Not much of a timelapse (interest-wise). I'm in the middle of upgrading to a mini 5+ with Pi 3B+. Going to mount the Pi on the outside of the electronics box so I have access to hdmi etc.
576 frames scaled to a 45s video with DuetLapse3 using a combination of time and layer capture.
Added bonus section at the startThis is a link to the folder in which I will place future timelapse recordings.
Shipwrecked Benchy !
In the interest of interesting timelapses; I thought I would try out the new "organic" supports in Pruse Slicer 2.6.0 Alpha.
This is the second of two benchies rotated bow up and listing. The first one suffered a lot from overheating (using PETG) so I added about 30% fan this second attempt. I suspect the "loiter time" with these supports meant that the nozzle was too close to some of the adjacent layers. In the timelapse you can see some of the supports breaking off - likely my fault as I made them thinner than the default settings.In any case - looks very promising. The benchy came out "ok" considering - but not a "great" benchy.
Other timelapses here:
https://photos.app.goo.gl/9FVSY79J4dkqyVxv9 -
Game of Thorns ?
What looks to be a thicket growing
Turns out to be this:
Don't think I can do much about the stringing. Pausing at home position at each layer change. Takes about 4 sec each time as I have to wait about 3 sec on the video lag before the image is taken.
Thanks! @yasas has started a new thread about collecting some calibration data:
https://forum.duet3d.com/topic/31907/collecting-timelapses-need-your-help
We would appreciate input from people to assist with his Masters research project.
