NO backlash function?
Marlin has M425 for backlash compensation. I have not seen anything like in Duet Firmware. Maybe I am missing something?
@mendelevium its on the wishlist i believe
@jay_s_uk
Thanks, my printer runs with reciprocating ballscrews and Z being not so heavy I am not happy with. -
@mendelevium add some weight?
shouldnt gravity take care of backlash in Z direction?
@oliof think if you run zhop?
@PCR unless you are running at 10,000mm/s^2 acceleration in z then I think gravity should still win right? Unless there is an awful lot of 'stiction' in the z bearings.
If it is from Z hop, surely you are always approaching the axis from the same direction (downwards), so backlash shouldn't be an issue? Or am I being naive and missing something...?
