G28 Z "Error: probe 0 not found"
The Z axis home'd properly one week ago, but not anymore.
The BL touch itself is good, and i cannot remember remotely touching it in the config.
I don't know what to do, please help.; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Jan 08 2022 17:50:57 GMT+0100 (Midden-Europese standaardtijd); General preferences
M550 P"Modix Big-60" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes forwards. X-Axis.
M569 P1 S0 ; physical drive 1 goes forwards. Y-Axis.
M569 P2 S0 ; physical drive 2 goes forwards. Z-Axis.
M569 P3 S1 ; physical drive 3 goes forwards. E0-Extruder.
;M92 X80.00 Y160.00 Z400.00 E420.00 ; set steps per mm
M92 X100 Y195 Z2000 E418.5:418.5
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z2000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
M906 X1800 Y1800 Z2400 E1000 I40 ; set motor currents (mA) and motor idle factor in per cent
M208 X610 Y610 Z610 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!^xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"!^ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S2 ; Define Z to use BLTouch probe; Z-Probe BLTouch on Duet WiFi
M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
M558 P7 C"^zprobe.in" H15 F120 T3000 A5 ; set Z probe type to bltouch and the dive height + speeds
M280 P7 S10 ; send control signal to BLTouch through servo/gpio 0"
G31 X20 Y0 Z3.3 P25; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
Z probe types 4, 6 and 7 (used in RRF 2.x) are no longer supported. Instead, use type 5 (filtered digital) or 8 (unfiltered digital) and use the C parameter to specify the input.
see here https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m558-set-z-probe-type
use P9 -
@jay_s_uk
how do i do that -
@3dorbit change the P value in M558
@jay_s_uk thanks a lot
